Bose QuietComfort 25 Battery Replacement
  1. Bose QuietComfort 25 Battery Replacement, Battery: шаг 1, изображение 1 из 2 Bose QuietComfort 25 Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • Locate the side designation in the interior of the earpiece.
    • The battery compartment is located on the top of the right-side earpiece, accessible via the latched door.
  2. Bose QuietComfort 25 Battery Replacement: шаг 2, изображение 1 из 2 Bose QuietComfort 25 Battery Replacement: шаг 2, изображение 2 из 2
    • Do not allow battery corrosion to come into contact with your skin or eyes.
    • Sometimes, batteries or the terminals they come into contact with can become corroded. Corrosion will appear as chalky-white or green.
    • If the compartment is not clean--coated with debris or corroded--use a cotton swab to carefully remove debris or corrosion from the terminal corrosion.
  3. Bose QuietComfort 25 Battery Replacement: шаг 3, изображение 1 из 1
    • Insert a new battery.
    • Make sure that the polarity of the battery is aligned correctly to the diagram on the inside of the cartridge.
Заключение
When finished with this guide process, the Bose QuietComfort 25 should be able to be played with the functioning noise-cancelling feature.
9 участников успешно повторили данное руководство.
Matt Jordan
Участник с: 01/17/17
942 Репутация
Автор 2 руководств
Команда
Western Carolina University, Team 1-2, Virtue Spring 2017 Участник Western Carolina University, Team 1-2, Virtue Spring 2017
WCU-VIRTUE-S17S1G2
4 членов
Автор 6 руководств
Один комментарий
Are there any option for replacing the latch together with the spring?
I wanted to replace these after a battery leak, but I'm unable to find any sources for the part needed unless you want to buy a full set of headphones from some one else.
Erik - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 32
За последние 30 дней: 126
За всё время: 12,423
