Введение
This guide aims to provide a step-by-step process to replace an earcup, the earcup provides more insulation and helps with isolating sound in the headphones.
Выберете то, что вам нужно
Locate the clips where the cushion is attached and slowly detach them.
After removing the cushion you should be exposing the cloth, carefully remove the glued part with tweezers and place your new one.
After removing the cloth you will expose a plastic plate with three 4 mm screws.
Grab your PH00 head and unscrew them.
Use a plastic tool to push the plate out, after taking out the screws it should pop right out.
