Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
The following guide explains in detailed steps including pictures on how to replace the control panel of the Bose 5 Sound Bar. The control panel is responsible for controlling the power and the output of the Bose 5 Sound Bar. It may be necessary to replace the control panel if the sound bar does not produce sound when it is plugged into the TV. Upon completion of the control panel replacement, the Bose 5 Sound Bar should work as expected. Otherwise, it would indicate that your system has a different problem.
Before using this guide, be sure to test different audio cables that connect the sound bar to the TV to confirm that the faulty part is coming from the sound bar. Before beginning, make sure to disconnect the sound bar from the TV.
Запчасти
Детали не указаны.
  1. Lay Bose Solo 5 with speakers facing away from you and bottom side facing upward.
    • Lay Bose Solo 5 with speakers facing away from you and bottom side facing upward.
  2. Remove the five 18.25mm screws with the Phillips #2 screw driver. Remove the five 18.25mm screws with the Phillips #2 screw driver.
    • Remove the five 18.25mm screws with the Phillips #2 screw driver.
  3. Наборы переключателей Nintendo
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Remove the gold plates snap connector from the circuit board by pulling it apart.
    • Remove the gold plates snap connector from the circuit board by pulling it apart.
  5. Using the plastic opening tool, lift the circuit board up and remove from housing.
    • Using the plastic opening tool, lift the circuit board up and remove from housing.
  6. Disconnect the cords running to the white connecter by pulling up on the tab until it is disconnected completely. Disconnect the cords running to the white connecter by pulling up on the tab until it is disconnected completely.
    • Disconnect the cords running to the white connecter by pulling up on the tab until it is disconnected completely.
Заключение
Emma
Участник с: 05.10.2018
473 Репутация
Автор 3 руководств
Команда
Sam Houston State, Team S15-G7, Blackburne Fall 2018 Участник Sam Houston State, Team S15-G7, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S15G7
2 членов
Автор 4 руководств
Один комментарий
Does anyone know where to buy a replacement logic board? I’ve been searching for a while now, no dice.
Tyler Barney - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 39
За последние 30 дней: 192
За всё время: 2,455
