Введение
This guide will help you replace the IR receiver in your Bose speaker.
Выберете то, что вам нужно
Gently pry the front mesh cover off of the sound dock using a metal spudger.
Using a T15 torx screwdriver, remove the 8mm screw holding the IR sensor to the speaker system.
Using tweezers or your fingers, gently remove the ribbon cable connecting the IR sensor to the system.
2 участников успешно повторили данное руководство.
