Введение
This guide will help you replace the IR receiver in your Bose speaker.
Выберете то, что вам нужно
Gently pry the front mesh cover off of the sound dock using a metal spudger.
Using a T15 torx screwdriver, remove the 8mm screw holding the IR sensor to the speaker system.
Using tweezers or your fingers, gently remove the ribbon cable connecting the IR sensor to the system.
I have bose sound duck portable. Remote are not working I was try to othere remote it's in side the bose spekers in self not working I got new censer still not working what I will it's be mouther brod in side problem any idea how to fixe the remote controls
2 участников успешно повторили данное руководство.
