Введение
This guide will help you replace the IR receiver in your Bose speaker.
Запчасти
Детали не указаны.
  1. Bose SoundDock Portable v2 IR Receiver Replacement, IR Receiver: step 1, image 1 of 3 Bose SoundDock Portable v2 IR Receiver Replacement, IR Receiver: step 1, image 2 of 3 Bose SoundDock Portable v2 IR Receiver Replacement, IR Receiver: step 1, image 3 of 3
    • Gently pry the front mesh cover off of the sound dock using a metal spudger.
    • The mesh is held on by small velcro strips so if you hear a tearing sound it is just the velcro coming apart.
  2. Bose SoundDock Portable v2 IR Receiver Replacement: step 2, image 1 of 1
    • Using a T15 torx screwdriver, remove the 8mm screw holding the IR sensor to the speaker system.
  3. Bose SoundDock Portable v2 IR Receiver Replacement: step 3, image 1 of 1
    • Using tweezers or your fingers, gently remove the ribbon cable connecting the IR sensor to the system.
    I have bose sound duck portable. Remote are not working I was try to othere remote it's in side the bose spekers in self not working I got new censer still not working what I will it's be mouther brod in side problem any idea how to fixe the remote controls
    Mssu Mssujohn - Ответить
Заключение
2 участников успешно повторили данное руководство.
Evan Low
Участник с: 14.04.2015
518 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 4-1, Maness Spring 2015 Участник Cal Poly, Team 4-1, Maness Spring 2015
CPSU-MANESS-S15S4G1
4 членов
Автор 5 руководств
Один комментарий
Hi my sounddock blocked suddenly and the green led always on. Do you now something about please... :(
jose - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 12
За последние 30 дней: 31
За всё время: 5,968
