Bose SoundDock Portable v2 Remote Battery Replacement
Выберете то, что вам нужно
  1. Bose SoundDock Portable v2 Remote Battery Replacement, Remote Battery: шаг 1, изображение 1 из 1
    • Using a quarter, turn the battery cover 1/8th of a turn counterclockwise.
  2. Bose SoundDock Portable v2 Remote Battery Replacement: шаг 2, изображение 1 из 2 Bose SoundDock Portable v2 Remote Battery Replacement: шаг 2, изображение 2 из 2
    • Remove cover and battery. The new battery should be placed with the positive (flat) side facing up.
    • The correct battery for your remote is a CR2032. You may also use a DL2032.
Заключение
Brodie Sutherland
Участник с: 04/14/15
312 Репутация
1 руководство автора
Команда
Cal Poly, Team 4-1, Maness Spring 2015 Участник Cal Poly, Team 4-1, Maness Spring 2015
CPSU-MANESS-S15S4G1
4 членов
Автор 5 руководств
Один комментарий
We have a Bose Wave radio w/remote. This remote is not the one shown here with a screw for the battery compartment. It's the type w/a sliding holder for the battery on the south end (bottom of the battery). Someone went to replace the battery and shoved the holder in upside down I believe. Consequently the holder will not come out all the way.
There must be a way to get it out without forcing it. There's a pinch clip you have to either squeeze or move to the left to disengage it from the locked position and free it up. Any ideas as to how to accomplish this? We appreciate a reply back so this would make our Christmas better.
Merry Christmas & Happy Holidays! Cheers!
asbirdiesingh - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 67
За последние 30 дней: 214
За всё время: 12,587
