Bose SoundDock Portable v2 Speaker Replacement
Выберете то, что вам нужно
  1. Bose SoundDock Portable v2 Speaker Replacement, Speaker: шаг 1, изображение 1 из 3 Bose SoundDock Portable v2 Speaker Replacement, Speaker: шаг 1, изображение 2 из 3 Bose SoundDock Portable v2 Speaker Replacement, Speaker: шаг 1, изображение 3 из 3
    • Gently pry the front mesh cover off of the SoundDock using a metal spudger.
    • The mesh is held on by small velcro strips so if you hear a tearing sound it is just the velcro coming apart
  2. Bose SoundDock Portable v2 Speaker Replacement: шаг 2, изображение 1 из 2 Bose SoundDock Portable v2 Speaker Replacement: шаг 2, изображение 2 из 2
    • Remove the four 16mm #2 screws holding the speaker to the base using a #2 screwdriver
    • Gently lift the speaker from the base.
    • Do not lift the speaker to far out of the base, you may damage the wires.
  3. Bose SoundDock Portable v2 Speaker Replacement: шаг 3, изображение 1 из 1
    • You will notice 2 coils of wire around the speaker's input tabs. Slide these coils off as un-winding the wires may break the wires. Slide the coils around your new driver.
Заключение
4 участников успешно повторили данное руководство.
Evan Low
Участник с: 04/14/15
551 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 4-1, Maness Spring 2015 Участник Cal Poly, Team 4-1, Maness Spring 2015
CPSU-MANESS-S15S4G1
4 членов
Автор 5 руководств
5 Комментариев
I am unsure of what to do in step #3…
Is the purpose to remove the speaker completely and place a brand new one? (Making sure not to pull the old speaker too far out as to not break any wire… ) ???
Edited comment:
I am not sure what they mean by "pins".
vero198099 - Ответить
Hi I just accidently pushed in that dome part in the middle a little and now it distorts. I tried using a vacuum but it didnt work. Please help!!!!!!!!
AJ Grape - Ответить
Try to see if there’s any way you can reduce the nozzle size of the vacuum cleaner you’re using - this should increase the flow rate, and possibly the amount of force applied over such a small area.
Alternatively, you can use a very very fine needle, bend the end of it, and use it to “hook” the cone. This method is really a last resort, as you want to avoid making even the smallest of holes.
Absolute last resort is replacing the speaker, which if you can find a replacement, should be pretty easy.
Colm Donnelly -
Need help love this speaker when it’s played loud it makes a load noise when the base is on changed aux lead think it’s the speaker what do I do
Chantelle Webb - Ответить
How do you cut on without remote
Chad Davenport - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 34
За всё время: 11,694
