Введение
When one or all of the buttons stop working on a device, it can be a frightening thing. Use this guide to help.
Выберете то, что вам нужно
Lift up the retaining flap on the button cable ZIF connector.
Pull the button cable straight out of the connector.
Carefully pull the ribbon cable through the rubber gasket that runs around the device.
To reassemble your device, follow these instructions in reverse order, starting from Step 6.
8 участников успешно повторили данное руководство.
3 Комментариев
I’m wondering the same thing. Where do you get the replacement Bose Soundlink Color button pad? We just bought a new charger because we thought that was the problem. But that didn’t make any difference. We still can’t turn the speaker on!
