Bose SoundLink Color Outer Casing Replacement
Выберете то, что вам нужно
  1. Bose SoundLink Color Outer Casing Replacement, Outer Casing: шаг 1, изображение 1 из 2 Bose SoundLink Color Outer Casing Replacement, Outer Casing: шаг 1, изображение 2 из 2
    • Four round, plastic plugs are located on the back of the device.
    • Using a metal spudger, carefully pry up the plastic covers.
    • The covers are all glued on, so be careful not to scar the casing when prying them off. If possible, use a spudger or plastic opening tool to remove them.
  2. Bose SoundLink Color Outer Casing Replacement: шаг 2, изображение 1 из 2 Bose SoundLink Color Outer Casing Replacement: шаг 2, изображение 2 из 2
    • Remove the four 1.8 cm-long T15 Torx Security screws from the outer case.
    • Some of these use T15 "Star" 5-point Torx security screws instead of the more common 6-point ones.
  3. Bose SoundLink Color Outer Casing Replacement: шаг 3, изображение 1 из 2 Bose SoundLink Color Outer Casing Replacement: шаг 3, изображение 2 из 2
    • Carefully open up the casing.
    • The top button pad may need to be re-glued upon installing the new casing.
Заключение
13 участников успешно повторили данное руководство.
Michael Thorn
Участник с: 03/31/16
557 Репутация
Автор 3 руководств
Команда
Eastern Washington University, Team 1-4, Giguere Spring 2016 Участник Eastern Washington University, Team 1-4, Giguere Spring 2016
EWU-GIGUERE-S16S1G4
5 членов
Автор 15 руководств
12 Комментариев
When I search for a 1.8 cm Torx Plus TR drill bit, I see a whole set from Amazon. Is there a particular number or head size just so I can purchase one drill bit?
jwm82 - Ответить
Hey, did you find out what size screwdriver you need?
kestis155 -
yes its the number 5 torque
art -
dose anyone know where to buy the outer casing for these? i need a mint colored one.
idixon16 - Ответить
I need more information on the Torx Plus bit can you provide the exact size as you used. The 1.8cm is not easy to search for. Brand and exact size number would help.
Joseph - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 25
За последние 30 дней: 137
За всё время: 29,318
