Введение
The back panel houses the motherboard for the speaker. It needs to be removed in order to replace the motherboard as well as several other components.
The motherboard in this guide contains capacitors which can hold a charge even when the speaker is powered off. Do not touch the as it may result in a shock.
Выберете то, что вам нужно
Turn the speaker over so that the rubber strips along the bottom are facing you.
Use the iFixit Opening Tool to peel back the rubber strip on the bottom-front edge.
Use a #2 Phillips screwdriver to remove each of the three 20mm screws on the bottom front edge of the speaker.
Slide the front panel with the mesh covering downwards to disconnect it from the SoundTouch 10 body.
Lift the panel away to reveal the speaker head.
Use a #2 Phillips screwdriver to remove each of the six 20mm screws located underneath the front panel.
Flip the speaker onto its back.
Loosen the adhesive by sliding a Metal Spudger under the edge where the back panel meets the speaker's body.
Use force with an iFixit Plastic Opening Tool to pry the back panel up from the speaker frame.
Pull up on the base of the speaker wire plug to disconnect it from the motherboard.
4 участников успешно повторили данное руководство.
