Введение
The Bose SoundTouch 10 bass port is a hollow plastic tube inside the speaker. Removing it allows you to clean out any dust/dirt that may be trapped inside. It also allows access to other components inside the speaker that are usually covered by the bass port.
The motherboard in this guide contains capacitors which can hold a charge even when the speaker is powered off. Do not touch the as it may result in a shock.
Выберете то, что вам нужно
Turn the speaker over so that the rubber strips along the bottom are facing you.
Use the iFixit Opening Tool to peel back the rubber strip on the bottom-front edge.
Use a #2 Phillips screwdriver to remove each of the three 20mm screws on the bottom front edge of the speaker.
Slide the front panel with the mesh covering downwards to disconnect it from the SoundTouch 10 body.
Lift the panel away to reveal the speaker head.
Use a #2 Phillips screwdriver to remove each of the six 20mm screws located underneath the front panel.
Flip the speaker onto its back.
Loosen the adhesive by sliding a Metal Spudger under the edge where the back panel meets the speaker's body.
Use force with an iFixit Plastic Opening Tool to pry the back panel up from the speaker frame.
Pull up on the base of the speaker wire plug to disconnect it from the motherboard.
Use a #0 Phillips screwdriver to remove each of the two 11mm screws attached to the bass port.
2 участников успешно повторили данное руководство.
