Введение
If the audio from your SoundTouch 10 is muffled, distorted, or completely silent, you may need to replace the speaker entirely. Be careful when handling the motherboard as it contains capacitors which may hold a charge even while the speaker is unplugged.
Выберете то, что вам нужно
Turn the speaker over so that the rubber strips along the bottom are facing you.
Use the iFixit Opening Tool to peel back the rubber strip on the bottom-front edge.
Use a #2 Phillips screwdriver to remove each of the three 20mm screws on the bottom front edge of the speaker.
Slide the front panel with the mesh covering downwards to disconnect it from the SoundTouch 10 body.
Lift the panel away to reveal the speaker head.
Use a #2 Phillips screwdriver to remove each of the six 20mm screws located underneath the front panel.
Flip the speaker onto its back.
Loosen the adhesive by sliding a Metal Spudger under the edge where the back panel meets the speaker's body.
Use force with an iFixit Plastic Opening Tool to pry the back panel up from the speaker frame.
Pull up on the base of the speaker wire plug to disconnect it from the motherboard.
Use a #2 Phillips screwdriver to remove each of the four 15mm screws holding the speaker in place.
4 участников успешно повторили данное руководство.
4 Комментариев
Hi I need to get a replacement for the driver. Would you know the specs or where to get them from? Bose support has not been very helpful with this , since I live outside of the US and repair would be expensive, I need to purchase the driver only to fix it myself. Any advise would be appreciated.
Hello I needed to reconnect my capacitor on my Bose Soundtouch 10 after dropping speaker. The IFixit steps to open the speaker were perfect! After reconnecting capacitor, shaking the speaker was no longer required.
BillJ - 06/30/20
