Выберете то, что вам нужно
Turn the device around.
From the top, lightly push down the back cover to release it.
Lift the bottom of the cover and pull it up.
With the bottom of the device facing you, pull down the trim pieces to remove from the device body.
Remove the two T-10 Torx screws
Remove the black casing
Pry off flat connector
2 участников успешно повторили данное руководство.
