Bose Soundlink II Button Cover Replacement
Выберете то, что вам нужно
  1. Bose Soundlink II Button Cover Replacement, Bose Soundlink II Cover Removal: шаг 1, изображение 1 из 1
    • Using a 2.5 mm hex wrench, remove the two 13 mm screws from the bottom of the speaker.
  2. Bose Soundlink II Button Cover Replacement: шаг 2, изображение 1 из 1
    • Push up on the back of the cover until it slides up slightly.
    • Pull the cover up and away from the speaker backing.
  3. Bose Soundlink II Button Cover Replacement, Side Cover: шаг 3, изображение 1 из 1
    • Remove the black electrical tape in order to reveal the screws attaching the side cover to the main body of the speaker. These screws are on the base of the device.
  4. Bose Soundlink II Button Cover Replacement: шаг 4, изображение 1 из 1
    • Using the T-10 star tip screwdriver, remove the two 13 mm screws located on the bottom of the speaker on each side of the battery pack.
  5. Bose Soundlink II Button Cover Replacement: шаг 5, изображение 1 из 3 Bose Soundlink II Button Cover Replacement: шаг 5, изображение 2 из 3 Bose Soundlink II Button Cover Replacement: шаг 5, изображение 3 из 3
    • Slide the silver side cover down toward the base of the speaker. The silver cover will come off easily.
  6. Bose Soundlink II Button Cover Replacement, Button Cover: шаг 6, изображение 1 из 1
    • Once the Bose Soundlink II Side Covers Removal has been completed, remove the two screws (13 mm) an inch below the buttons on the back of the speaker using the T-10 star tip screwdriver.
  7. Bose Soundlink II Button Cover Replacement: шаг 7, изображение 1 из 1
    • Using a tool such as a spudger or plastic opening tool, insert the end into one of the small indentations located on the back of the speaker. Start either on the indentation farthest to the right or to the left.
    • Pry up with the spudger or plastic opening tool so that the cover is pushed up slightly.
  8. Bose Soundlink II Button Cover Replacement: шаг 8, изображение 1 из 1
    • Repeat this process with each of the indentations, working your way left or right (depending on where you start).
  9. Bose Soundlink II Button Cover Replacement: шаг 9, изображение 1 из 1
    • Pull the cover around the buttons off. If you’d like, you can remove the button cover as well.
Заключение
2 человек успешно провели ремонт по этому руководству.
John P Loughran
Участник с: 03/02/17
472 Репутация
Автор 3 руководств
Команда
IUPUI, Team S3-G3, Harley Spring 2017 Участник IUPUI, Team S3-G3, Harley Spring 2017
IUPUI-HARLEY-S17S3G3
4 членов
Автор 3 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 13
За всё время: 2,480
