Введение
This guide gets you into this classic coffee grinder.(You will get some extra jealous looks from your hipster friends because it's soooo vintage ;-D)
Выберете то, что вам нужно
First, remove the coffee powder container
Now it's time to rotate the bean container anti-clockwise to remove it from the machine
Back to the bean container!
After a short cleaning action you should be able to loosen this three Philips screws
Now the bean container is completely disassembled and ready for some cleaning work!
16 участников успешно повторили данное руководство.
9 Комментариев
Hi Daniel,
Thanks for the tutorial.
Would you have, by any chance, the usermanual of the grinder?
I’m wondering to what grinding size the numbering is corresponding to.
Many thanks! :)
Best regards,
Greg
I have this same issue! Did you ever find out? Im guessing that the grind size of the KMM1 is the same as the KMM20? So left (where it says mocca)for finest grind, right for the largest grind?
Look at the explosion view
Umm.. My bottom burr doesn’t seem to have screws and look like rivits. maybe previous owner stripped the screws :(
Mine has something like rivets as well. I used toothpicks and cotton swabs to clean as much as I could,, then had some luck running dried couscous through the grinder. Softer than rice and seemed to pick up the last bits of residue.
