Braven BRV-1M Battery Replacement
Выберете то, что вам нужно
  1. Braven BRV-1M Battery Replacement, Outer Casing: шаг 1, изображение 1 из 1
    • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
  2. Braven BRV-1M Battery Replacement: шаг 2, изображение 1 из 1
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Battery Replacement: шаг 3, изображение 1 из 1
    • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
  4. Braven BRV-1M Battery Replacement: шаг 4, изображение 1 из 1
    • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
  5. Braven BRV-1M Battery Replacement, Motherboard: шаг 5, изображение 1 из 1
    • To remove the motherboard, proceed to unscrew the 3 Phillips #00 bit type, 13mm long screws located on both sides of the motherboard.
  6. Braven BRV-1M Battery Replacement: шаг 6, изображение 1 из 1
    • Then, proceed to unscrew the 5 Phillips #00 bit type, 9mm long screws located on the face of the charging dock.
  7. Braven BRV-1M Battery Replacement: шаг 7, изображение 1 из 1
    • Disconnect the two 4-pin auxiliary button register cables connected on both sides of the motherboard.
  8. Braven BRV-1M Battery Replacement: шаг 8, изображение 1 из 1
    • Once disconnected, carefully remove the motherboard by pulling upwards.
  9. Braven BRV-1M Battery Replacement, Battery: шаг 9, изображение 1 из 1
    • To remove the battery, unscrew the 2 Phillips #00 bit type, 9 mm long screws on both sides of the battery.
  10. Braven BRV-1M Battery Replacement: шаг 10, изображение 1 из 1
    • Gently pull the battery from the housing of the device while disconnecting the red, white and black wires coming from the battery.
Заключение
Erik Oliva
Участник с: 02/14/18
607 Репутация
Автор 6 руководств
Команда
USF Tampa, Team S2-G1, Eyestone Spring 2018 Участник USF Tampa, Team S2-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S2G1
4 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 60
За всё время: 2,294
