Введение
Having a damaged outer casing can allow foreign material to enter the speaker. By following this guide, one can learn how to remove and replace the outer case of the device.
Выберете то, что вам нужно
To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
Еще один человек закончил это руководство.
Один комментарий
Where can I buy parts for this speaker? My rear charging door has broken off disabling the ruggedness. Be easier to buy versus build new piece.
