Введение
Learn how to properly open the Braven BRV-1s and remove the motherboard.
Выберете то, что вам нужно
Using a 0mm Philips Head screwdriver, unscrew the four 0.9mm screws located on the bottom of your device.
Take a metal spudger and insert it into the bottom seam.
Work the spudger around the bottom seam making sure that bottom of the speaker is no longer glued onto the rest of the speaker.
Using a 0mm Philips Head screwdriver, unscrew the 0.6mm 10 screws located around the outside of the woofer.
Insert the metal spudger between the seam of the woofer.
Work the spudger around the seam to loosen the woofer and get rid of excess glue.
Using a 0mm Philips Head screwdriver unscrew the three 0.6mm screws on the motherboard.
You can also just pull up this circuit board carefully; it is easier if you scrape off the glue that is holding it to the posterior frame (arrow)
2 участников успешно повторили данное руководство.
