Введение
This is a step-by-step guide demonstrates how to remove the battery.
WARNING: This is a lithium battery which should be handled with care.
TIPS:
- Be sure to check the screwdriver heads before performing this task; otherwise, screws may become damaged.
- Use an ice cube tray or egg carton, place each screw in its own cup to organize the screws.
Выберете то, что вам нужно
Flip the Braven BRV-X upside down so you are facing the bottom side.
With the H1.5 Head Screwdriver, unscrew the four screws.
Using the #0 Phillips screwdriver, unscrew the four screws on the four corners of the bottom side.
Gently remove the outer casing, which should reveal the inner shell.
With a Jimmy, cut the two warranty seals on either side.
Next, remove the 18 screws with a #00 Phillips screwdriver.
Remove the black foam squares from the red, yellow, and black wire on the top right side of the device.
Now that the three wires are exposed, follow the wires to the white base that is plugged into the motherboard.
Using the tech knife, carefully remove the glue that keeps the plug in place.
Using the tweezers, carefully disconnect the plug from the motherboard.
The battery's black shell is connected to the motherboard with four screws. Use the #00 Phillips screwdriver to remove the four screws.
Slide the blue battery out from the black container. Your battery is now removed from the device and is ready for replacement.
5 участников успешно повторили данное руководство.
10 Комментариев
Thank you for the replacement steps - do you know where I could buy a replacement battery?
Anyone ever figure out what battery they needed?
I also would love to know what battery is actually needed for this.
Parallel or series connection?
