Введение
This guide will show how to remove and replace the bread grabber of the Brentwood TS-292B.
Запчасти
Никакие детали не требуются.
  1. Remove all 6mm screws with the Phillips #2 screwdriver from the bottom of the toaster
    • Remove all 6mm screws with the Phillips #2 screwdriver from the bottom of the toaster
  2. Pull lever tab away from the toaster with force (after pushing in the small tab located to the left)
    • Pull lever tab away from the toaster with force (after pushing in the small tab located to the left)
    • Remove toaster cover carefully
    • Detach the bundled cable connector by carefully pulling it away from the circuit board
    • Make sure to keep toasting lever down
    • Undo tabs with metal spudger on both sides
    • Pinch and carefully remove from toaster
Заключение
Elly Ayala
Участник с: 21.09.2018
739 Репутация
Автор 5 руководств
Команда
University of North Texas, Team S8-G7, Riccardelli Fall 2018 Member of University of North Texas, Team S8-G7, Riccardelli Fall 2018
UNT-RICCARDELLI-F18S8G7
4 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 1
За 7 дней: 3
За 30 дней: 27
За всё время: 77
