Введение
This guide will show how to remove and replace the power wire in a Brentwood TS-292B toaster.
Выберете то, что вам нужно
Remove the five 6mm screws on the bottom of the toaster with a Phillips #2 screw driver.
Unplug the wire connecting the casing to the circuit board to fully remove the toaster casing.
Pull back on the black tab that is holding the circuit board in place.
While pulling the tab back, lift up on the circuit board.
