Введение
Replacing the heating tank should it fail to work.
Инструменты
Запчасти
  1. Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: step 1, image 1 of 3 Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: step 1, image 2 of 3 Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: step 1, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
  2. Breville BKC600XL Heating Tank Replacement, Black Water Inlet: step 2, image 1 of 2 Breville BKC600XL Heating Tank Replacement, Black Water Inlet: step 2, image 2 of 2
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
  3. Breville BKC600XL Heating Tank Replacement, Bottom Cover #2: step 3, image 1 of 2 Breville BKC600XL Heating Tank Replacement, Bottom Cover #2: step 3, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
  4. Breville BKC600XL Heating Tank Replacement, Power Cord: step 4, image 1 of 2 Breville BKC600XL Heating Tank Replacement, Power Cord: step 4, image 2 of 2
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
  5. Breville BKC600XL Heating Tank Replacement, Clear Hose: step 5, image 1 of 2 Breville BKC600XL Heating Tank Replacement, Clear Hose: step 5, image 2 of 2
    • Identify the hose that connects to the heating tank. (Observe that it is held up on a small hook.)
    • Push down on the hook and carefully move the hose from its grip.
  6. Breville BKC600XL Heating Tank Replacement, Heating Tank: step 6, image 1 of 1
    • Carefully pull out the heating tank by hand.
    • The heating tank may still be hot. Exercise caution when grabbing hold of the tank. If necessary, wait four to six hours after last use.
    • Reminder for reassembly; You will need a new band to tie the hose back to the heating tank.
Заключение
2 участников успешно повторили данное руководство.
Antonio
Участник с: 26.09.2012
120 Репутация
Автор 6 руководств
Cal Poly, Team 1-3, Propen Fall 2012 Участник Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 членов
Автор 6 руководств
0 Comments
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 14
За всё время: 4,363
