Breville BKC600XL On/Off Switch Replacement
Выберете то, что вам нужно
  1. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: шаг 1, изображение 1 из 3 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: шаг 1, изображение 2 из 3 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: шаг 1, изображение 3 из 3
    • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
  2. Breville BKC600XL On/Off Switch Replacement, Black Water Inlet: шаг 2, изображение 1 из 2 Breville BKC600XL On/Off Switch Replacement, Black Water Inlet: шаг 2, изображение 2 из 2
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
  3. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #2: шаг 3, изображение 1 из 2 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #2: шаг 3, изображение 2 из 2
    • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
  4. Breville BKC600XL On/Off Switch Replacement, Power Cord: шаг 4, изображение 1 из 2 Breville BKC600XL On/Off Switch Replacement, Power Cord: шаг 4, изображение 2 из 2
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
  5. Breville BKC600XL On/Off Switch Replacement, On/Off Switch: шаг 5, изображение 1 из 1
    • Carefully pull both the red and blue wires that covered at the tip.
    • Do not yank them out from the other end. Move them aside and out of the way.
  6. Breville BKC600XL On/Off Switch Replacement: шаг 6, изображение 1 из 1
    • Carefully remove the On/Off Switch from its slot on the outside cover.
    • The wires for the switch need to be tied back into the wires that lead to the battery. If needed, use electrical tape.
Заключение
2 участников успешно повторили данное руководство.
Antonio
Участник с: 09/26/12
120 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 1-3, Propen Fall 2012 Участник Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 членов
Автор 6 руководств
2 Комментариев
Any source for the switch?
Mark Bell - Ответить
Thanks to this great post, I replaced my Breville BKC700XL On/Off Switch. The momentary switch is JR Products 12815 Black SPST Mini Mom-On/Off Switch, $8 on Amazon. https://www.amazon.com/dp/B002UC6QY0?psc...
Now, my Breville single serve is like new. I almost ordered a new machine, then I found ifixit. Kudos to you guys.
Boyd Gilbert - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 18
За всё время: 3,537
