Введение
Replacing the On/Off switch should the wiring become faulty.
Выберете то, что вам нужно
Use a Phillips #0 screwdriver to remove the following ten screws:
Four 18mm Phillips screws.
Four 9.75mm Phillips screws.
Two 8mm Phillips screws.
Use a Phillips #0 screwdriver to remove the following six screws:
Six 14.5mm Phillips screws.
Remove the power cord from the groove. (the black cord that leads into the green wire.)
Carefully pull both the red and blue wires that covered at the tip.
Carefully remove the On/Off Switch from its slot on the outside cover.
Thanks to this great post, I replaced my Breville BKC700XL On/Off Switch. The momentary switch is JR Products 12815 Black SPST Mini Mom-On/Off Switch, $8 on Amazon. https://www.amazon.com/dp/B002UC6QY0?psc...
Now, my Breville single serve is like new. I almost ordered a new machine, then I found ifixit. Kudos to you guys.
2 участников успешно повторили данное руководство.
2 Комментариев
