Введение
Replacing the water valve should it fail to work.
Выберете то, что вам нужно
Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
Remove the grey plastic casing.
Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
Cut the band connecting the hose to the water valve.
Remove the water valve.
2 Комментариев
Where can I buy a new water valve assembly? Are they custom to the device or generally available ? Thanks!
Hi same question :)
