Введение
This guide will show you how to replace the food pusher that is responsible for pushing the ingredients into the blades of the juicer. Always remember to unplug the juicer before disassembling.
Place the juicer on a flat surface. Make sure the juicer is unplugged and in the "off" position. For the following steps, the pulp basket is on the left.
Tilt the juicer slightly to the right so the pulp basket is off of your surface.
Place one hand on either side of the safety locking arm.
Disengage the locking mechanism by pulling down on the lever with even pressure. The lever should be free to move up or down once it has been properly disengaged.
Firmly grip both sides of the juicer. Twist clock-wise and lift to remove the lid.
Place one hand on the food pusher grip, and pull upward. Continue to slide the food pusher until it has fully cleared the food chute.
