Введение
Removing the air filter is really simple. It only takes one one screw to be removed and the rest can be done with your hands. The air filter should be replaced annually.
Выберете то, что вам нужно
Use a Flathead #4 screw driver to remove the 40mm screw that holds the air filter case in place.
6 участников успешно повторили данное руководство.
2 Комментариев
Good information, although it didn't resolve my issue. Thanks for sharing
This is a power wash motor water will not come out
