Введение
Follow these steps to remove the muffler from your Briggs and Stratton 675 engine. Once removed, a damaged muffler can be replaced or a dirty one cleaned. The muffler can become dirty or damaged over time. It is important to keep it clear of debris so that the exhaust coming from the engine can flow normally.
Выберете то, что вам нужно
Use a socket wrench with a 1/4" hex bit or a 1/4" wrench to remove the three 13mm screws holding the outer flange.
Remove the flange.
Use a pair of needle nose pliers to bend back the two metal tabs on either side of the remaining screws.
Use a socket wrench with a 7/16" hex bit or 7/16" wrench to remove the two remaining 75mm screws.
Еще один человек закончил это руководство.
