Введение
Use this guide to replace a worn out tire ring for the bobbin winder of a Brother CS-80 sewing machine.
Over time and with constant usage, the bobbin winder tire ring in a Brother CS-80 sewing machine can wear out, break, or even disintegrate. You may need to replace your tire ring if your machine has issues with winding the bobbin correctly.
Выберете то, что вам нужно
Use a flathead screwdriver to pry off the plastic plate that surrounds the bobbin shuttle.
Pry off the bobbin winder thread spool pin and the attached bottom plate of the bobbin winder area.
Remove the 8 mm Phillips screw from the metal plate to the right of the motherboard.
Open the thread compartment.
Press the back level on left side of the machine to eject the thread cassette compartment.
Remove the thread cassette compartment by pulling it up.
Remove the front clear shield to the thread cassette compartment holder by pulling it away from the machine.
Remove the single 19 mm Phillips head screw from the back of the internal thread cassette compartment area.
Remove the three large 19 mm Phillips head screws from the back left face of the machine.
Completely pull apart the two halves of the machine.
Set aside the front side piece.
Place the back piece down so that the inside faces upwards.
Remove the gold 9 mm Phillips screw from the front right of the motherboard.
Remove the two silver 7 mm Phillips head screws from the front and back of the left side of the motherboard.
Flip the motherboard over so it rests upside down and away from the balance wheel.
To reassemble your sewing machine, follow the disassembly instructions in reverse order.
