Введение
Before you begin, make absolutely sure that you need to actually replace this module. Here are some solutions to common wireless networking problems
If all else fails, continue with this guide.
Выберете то, что вам нужно
Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
Lift up the front panel from the device.
Gently lift up and disconnect the data cables that attach the panel to the printer.
Unscrew the 14.1mm screw located at the left side of the device.
Unscrew the 12.1mm screw to the right of the 14.1mm screw.
Separate the two clips that hold the module in place.
Lift up the module.
To reassemble your wireless module, follow these instructions in reverse order.
