Введение
The Brother PT-1010 requires 6-AAA batteries. The batteries are organized in two layers one on top of the other. This guide will inform you on proper battery replacement.
Remove dead batteries one at a time by pulling up on the side indicated with a + symbol.
Insert the first battery with the flat side (indicated by a - symbol on the battery) facing to the left of the battery compartment.
Do the same thing to insert the next 2 batteries.
The next 3 batteries will be inserted on top of the others.
Insert the 4th battery with the flat side (indicated by the - symbol on the battery) facing to the right of the battery compartment.
Еще один человек закончил это руководство.
