Brother PT-1010 Cassette Tape Replacement
Выберете то, что вам нужно
  1. Brother PT-1010 Cassette Tape Replacement, Remove Back Cover: шаг 1, изображение 1 из 1
    • Remove the back cover of the device by simultaneously pressing down on the indication arrows on the top center, then pulling toward you.
  2. Brother PT-1010 Cassette Tape Replacement, Insert Tape Cassette: шаг 2, изображение 1 из 1
    • Brother TZ tape is required for this replacement process. We don't have the tape cassette but you should be able to insert tape cassette into the red marked area as shown in the picture.
    • Insert tape cassette into the red marked area as shown in the picture.
    • Make sure the cassette snaps into place by applying a small amount of pressure.
Заключение
Haley Sweet
Участник с: 10/30/14
460 Репутация
Автор 4 руководств
Команда
Baylor, Team 4-4, Williams Fall 2014 Участник Baylor, Team 4-4, Williams Fall 2014
BU-WILLIAMS-F14S4G4
4 членов
Автор 4 руководств
3 Комментариев
So if you've replaced the cassette and it still won't print now what??
Sara Mullaney - Ответить
This was supposed to help with model PT-450D which looks nothing like this. Please help. I can’t REMOVE / replace the cassette !!! It is STUCK inside the label printer!
af4k - Ответить
I have a PT-1880 model and replaced the cassette, but whenever I type something to label something, the label comes out blank. Can someone help me on this? I’ve been needing help on this for a while now.
Yael Rzoque - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 3,246
