Brother PT-1290 Tape Cassette Replacement
  1. Brother PT-1290 Tape Cassette Replacement, Removing the back piece of the label maker.: шаг 1, изображение 1 из 2 Brother PT-1290 Tape Cassette Replacement, Removing the back piece of the label maker.: шаг 1, изображение 2 из 2
    • There is a plastic tab located on the back of the label maker near the top. The tab has ridges on it to help you identify where to press. Push on this tab to release the back of the label maker.
    • Gently pull the label maker apart - it will split in half.
    • Be careful! The electronics inside are very sensitive and easily damaged.
  2. Brother PT-1290 Tape Cassette Replacement, Removing batteries or AC adapter.: шаг 2, изображение 1 из 2 Brother PT-1290 Tape Cassette Replacement, Removing batteries or AC adapter.: шаг 2, изображение 2 из 2
    • Remove the AAA batteries before you proceed on to replacing the tape cassette.
  3. Brother PT-1290 Tape Cassette Replacement, Replacing tape cassette.: шаг 3, изображение 1 из 2 Brother PT-1290 Tape Cassette Replacement, Replacing tape cassette.: шаг 3, изображение 2 из 2
    • Align and insert a new tape cassette. Make sure the center of the cassette snaps into place. The tape must feed between the tape guides.
    • If the ribbon has become too loose, use your finger to turn the white wheel in the direction of the arrow on the tape cassette. This will wind up any excess tape.
    • Only use Brother TZ tapes with this machine.
  4. Brother PT-1290 Tape Cassette Replacement, Evaluating: шаг 4, изображение 1 из 1
    • Place the batteries back inside, then close the cover.
    • Check that all six batteries are inserted correctly.
  5. Brother PT-1290 Tape Cassette Replacement, Feeding Tape.: шаг 5, изображение 1 из 1
    • To test the new cassette, make a new label. Press "Shift" and "Print" to feed the tape, then use the cutting lever on the upper-right corner of the machine.
Заключение
Lorraine Canez
Участник с: 10/25/14
318 Репутация
Автор 3 руководств
Команда
Gateway, Team 1-4, Johnson Fall 2014 Участник Gateway, Team 1-4, Johnson Fall 2014
GCC-JOHNSON-F14S1G4
3 членов
Автор 6 руководств
Один комментарий
Wie wird die Kassette eingesetzt
Uwe Seiler - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 41
За всё время: 19,772
