Введение
In order to switch the stitching styles of your sewing machine, the stitch select knob must be properly functioning. This guide will show the steps for replacement.
Запчасти
Никакие детали не требуются.
  1. Place the machine on a solid surface.
    • Place the machine on a solid surface.
    • Remove the 14mm Phillips #2 screw holding on the face cover.
  2. Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
    • Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
  3. Lay the machine on its side.
    • Lay the machine on its side.
    • Remove the four 10mm Phillips #2 screws that hold the bottom panel in place.
    • The feet will come off with the screws.
  4. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Remove the bottom panel.
    • Remove the bottom panel.
  6. Place the machine upright.
    • Place the machine upright.
    • Remove the rear casing.
    • You may have to wiggle the panel and pull at the same time.
  7. Adjust the knob to gain access to the phillips head screw.
    • Adjust the knob to gain access to the phillips head screw.
  8. Remove the 14mm Phillips #2 screw.
    • Remove the 14mm Phillips #2 screw.
  9. Remove the knob.
    • Remove the knob.
Заключение
Kevin Bickers
Участник с: 05.02.2014
601 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 2-12, Amido Winter 2014 Member of Cal Poly, Team 2-12, Amido Winter 2014
CPSU-AMIDO-W14S2G12
4 членов
Автор 6 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 1
За 7 дней: 2
За 30 дней: 8
За всё время: 516
