Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Follow this guide to remove a bush pump's head and handle for repair or replacement. Be sure to use at least two people when following this guide to prevent injury, as the pump head can be heavy.
  1. Test pump performance by pumping 40 strokes. An effective pump should return at least 10 liters.
    • Test pump performance by pumping 40 strokes.
    • An effective pump should return at least 10 liters.
  2. Remove the two pins connecting the handle to the slider. Remove the two pins connecting the handle to the slider.
    • Remove the two pins connecting the handle to the slider.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Pull the two lever arms away from the slider. Pull the two lever arms away from the slider.
    • Pull the two lever arms away from the slider.
  5. Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame. Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame.
    • Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame.
  6. Throughout this step, make sure you support the handle and head with at least three hands. Slide the bearing rod out of the head. Inspect the bearing rod and head for any wear or tear.
    • Throughout this step, make sure you support the handle and head with at least three hands.
    • Slide the bearing rod out of the head.
    • Inspect the bearing rod and head for any wear or tear.
  7. Remove the head and handle, and place them on a clean surface to prevent contamination.
    • Remove the head and handle, and place them on a clean surface to prevent contamination.
Заключение
Jake Devincenzi
Участник с: 18.04.2011
112 165 Репутация
Автор 57 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 103
