Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Replacing the button board requires you to almost completely disassemble the device and solder several points. The process is feasible even if one lacks soldering experience.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:iOpener$19.99
Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
Lift and remove the counterweight.
Remove the two 9 mm screws that hold the main printed circuit board onto the rest of the iP37; you will need a Phillips #2 driver to do this.
Slowly lift the PCB away from the rest of the device
Remove the ribbon by first removing the brown insert piece from the connector on the button board
Pull the ribbon out of the connector on the button board by the blue tab.
Remove the four 6 mm screws that secure the button controller PCB to the rest of the device; you will need a Phillips #2 driver for this task.
Lift the PCB away from the rest of the device.
Using a soldering wick and a soldering iron, remove the solder from the red and black wire ends on the other side of the board.
