CCM Ice Skates Steel Blade Replacement
Выберете то, что вам нужно
  1. CCM Ice Skates Steel Blade Replacement, Steel Blade On CCM Skates: шаг 1, изображение 1 из 1
    • Place the palm of one hand over the laces at the middle of the skate boot.
    • Close that palm and firmly grasp the skate.
    • Use the other hand to grab and remove any skate guard.
  2. CCM Ice Skates Steel Blade Replacement: шаг 2, изображение 1 из 1
    • Place the heel/back portion of the skate on the table.
    • Firmly grasp the toe of the skate with one hand.
    • Insert the flat head screwdriver from a multi-tool into the groove of the first screw and hold.
  3. CCM Ice Skates Steel Blade Replacement: шаг 3, изображение 1 из 1
    • Using multi-tool pliers, grab hold of the fastener on the other side of the first screw.
    • Turn the flat head screwdriver in a counter clockwise rotation until it is loose.
  4. CCM Ice Skates Steel Blade Replacement: шаг 4, изображение 1 из 1
    • Remove the loosened screw from the white plastic blade holder.
    • Insert the screwdriver into the fastener and apply pressure to remove the fastener.
  5. CCM Ice Skates Steel Blade Replacement: шаг 5, изображение 1 из 1
    • Insert the flat head screwdriver from a multi-tool into the groove of the second screw and hold.
  6. CCM Ice Skates Steel Blade Replacement: шаг 6, изображение 1 из 1
    • Using multi-tool pliers, grab hold of the fastener on the other side of the second screw.
  7. CCM Ice Skates Steel Blade Replacement: шаг 7, изображение 1 из 1
  8. CCM Ice Skates Steel Blade Replacement: шаг 8, изображение 1 из 1
    • Wrap a hand in a cloth towel.
    • Pinch the two flat sides of the metal blade between the thumb and index finger.
    • Do not touch the bottom or edges of the blade.
  9. CCM Ice Skates Steel Blade Replacement: шаг 9, изображение 1 из 1
    • Apply pressure to the sides of the blade with your fingers.
    • Slowly pull the blade upward.
    • To avoid injury, do not pull the blade up in one quick motion.
Заключение
Steven Marcyan
Участник с: 10/04/17
101 Репутация
1 руководство автора
Команда
Michigan Tech, Team S5-G9, Galliah Fall 2017 Участник Michigan Tech, Team S5-G9, Galliah Fall 2017
MTU-GALLIAH-F17S5G9
1 член
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 15
За последние 30 дней: 38
За всё время: 5,986
