Введение
The CHI Spin and Curl Rotating Curler should work efficiently when plugged in. If the device still does not work after changing batteries or checking the power source, the issue may lie within the power cord. This guide will demonstrate how to replace the damaged power cord and fix the device.
WARNING: electricity hazard. The individual repairing should be aware of the danger of working on this project while the electricity is running on the device.
Выберете то, что вам нужно
Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
Toward the bottom of the device, grab the swivel power cord.
Gently pull the power cord to detach it from the CHI Spin N Curl
2 человек успешно провели ремонт по этому руководству.
