Введение
This guide will go over how to install O-rings on the backspace, spacebar, shift, and enter keys on your keyboard.
Запчасти
  1. Remove keycaps surrounding the key you'd like to install an O-ring under by following the remove small keycaps guide. Remove keycaps surrounding the key you'd like to install an O-ring under by following the remove small keycaps guide. Remove keycaps surrounding the key you'd like to install an O-ring under by following the remove small keycaps guide.
  2. Pull the large keycap upward with your fingers until the cap separates from the plastic rings underneath the cap. If the metal bar beneath the cap comes loose during removal, snap it back in place.
    • Pull the large keycap upward with your fingers until the cap separates from the plastic rings underneath the cap. If the metal bar beneath the cap comes loose during removal, snap it back in place.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Remove the plastic rings from the keycap. Remove the plastic rings from the keycap. Remove the plastic rings from the keycap.
    • Remove the plastic rings from the keycap.
  5. Place the O-rings around the nubs underneath the keycap at each circled locations. Place the O-rings around the nubs underneath the keycap at each circled locations.
    • Place the O-rings around the nubs underneath the keycap at each circled locations.
Заключение
Shiva Empranthiri
Участник с: 12.10.2014
736 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 6-23, Maness Fall 2014 Member of Cal Poly, Team 6-23, Maness Fall 2014
CPSU-MANESS-F14S6G23
4 членов
Автор 6 руководств
Один комментарий
Best choice if you want all the “click” but none of the “clack” on your mechanical keyboard
Cherry Mx Black Rubber O-rings (125 pcs -EPDM – 40A) €3,98
Cherry Mx Black Rubber O-rings (90 pcs -EPDM – 40A) €3,48
[NL] O-rings Webstore http://tigri.bigcartel.com
Specs
Material: EPDM Industrial Grade Rubber
Color: Black
Hardness: 40A
Thickness: 1,50 mm (0.059 in)
Packaging: 125 pcs/bag or 90 pcs/bag
tigriorings - Ответить
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 4
За всё время: 1,108
