Введение
When your cabinet is hanging on just one hinge, the door is unable to close all the way. This can damage the wood on the cabinet and the hinge itself. With this quick and easy guide to replace a broken hinge, you can save your cabinet door.
Unlike other hinge replacement guides on iFixit, we're focusing on replacing a butt hinge, which is better for holding heavier items than others. It is for this reason that it's so important to replace any broken butt hinge—the possibility of damaging your heavy cabinet door is more likely.
Выберете то, что вам нужно
Determine where the cabinet needs repair: on the top or bottom hinge.
Measure the hinge to make sure you have the correct size of your butt hinge.
Measure the distance between the screws and the height and width of the hinge to get the correct hinge.
Remove the screws from the door with a Phillips #00 screwdriver and remove the hinge.
Tighten the hinge into place using the same screws with your Phillips #00 screwdriver.
If the door closes parallel to any surrounding cabinets, your fix is complete!
