Cabinet Magnetic Catch Replacement
Выберете то, что вам нужно
  1. Cabinet Magnetic Catch Replacement, Cabinet Magnet Catch: шаг 1, изображение 1 из 2 Cabinet Magnetic Catch Replacement, Cabinet Magnet Catch: шаг 1, изображение 2 из 2
    • Remove two screws from the the old magnetic catch using a Phillips #0 screwdriver.
    • Remove the magnetic catch from the shelf.
    • It is recommended you use a stubby screwdriver since you will be dealing with tight spaces of the cabinet shelf.
  2. Cabinet Magnetic Catch Replacement: шаг 2, изображение 1 из 1
    • Remove the screws securing the plates to the cabinet doors using a Phillips #0 screwdriver. Remove the plates.
    • Do this on the both sides.
  3. Cabinet Magnetic Catch Replacement: шаг 3, изображение 1 из 3 Cabinet Magnetic Catch Replacement: шаг 3, изображение 2 из 3 Cabinet Magnetic Catch Replacement: шаг 3, изображение 3 из 3
    • Place the new magnetic catch on the center of the shelf cabinet.
    • Ensure it is adjusted carefully by moving its width halfway out of the cabinet and aligned on each side.
  4. Cabinet Magnetic Catch Replacement: шаг 4, изображение 1 из 1
    • With your graphite pencil, mark the location of the screw holes so you know exactly where you placed it in case you get lost.
  5. Cabinet Magnetic Catch Replacement: шаг 5, изображение 1 из 1
    • Screw in two 10 mm screws on the new magnetic catch using a Phillips #0 screwdriver to secure it in place.
    • Ensure that you are maintaining alignment of the magnetic catch with the help of Step 4. Otherwise, you will repeat Step 3.
    • You may reuse the old screws from the removal in Step 1 to install the new magnetic catch.
  6. Cabinet Magnetic Catch Replacement: шаг 6, изображение 1 из 1
    • Close the cabinet and mark down the side of the cabinet door using a graphite pencil.
    • Do this on the other side.
  7. Cabinet Magnetic Catch Replacement: шаг 7, изображение 1 из 1
    • Screw in one 5mm screw on the new magnetic plate using a Phillips #0 screwdriver to secure it in place on one side of the cabinet door.
    • Ensure that you are maintaining alignment of the magnetic plates with the help of Step 6 and old screw holes.
    • Do this step on the other side with the second 5mm screw.
    • You may reuse the old screws from the removal in Step 2 to install the new magnetic plates.
  8. Cabinet Magnetic Catch Replacement: шаг 8, изображение 1 из 3 Cabinet Magnetic Catch Replacement: шаг 8, изображение 2 из 3 Cabinet Magnetic Catch Replacement: шаг 8, изображение 3 из 3
    • Test the cabinet magnetic catch by closing it.
    • You are finished when the cabinet stays closed after letting your hands go.
Заключение
You have finished the replacement of cabinet magnetic catch.
Еще один человек закончил это руководство.
Brian Hegina
Участник с: 06/30/21
184 Репутация
1 руководство автора
Команда
York University, Team S2-G10, Melo-Thaiss Summer 2021 Участник York University, Team S2-G10, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S2G10
1 член
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 24
За последние 30 дней: 136
За всё время: 3,227
