Выберете то, что вам нужно
Remove the lower glide pads at the bottom of the mouse.
Use a screw driver to remove the screws highlighted here.
Lift the cover where the screws sat and shift it backwards slightly (away from the cable). Everything else inside the mouse comes loose with this step.
The electronics board contains:
5 small buttons
one mechanical rotary encoder (of the mouse wheel)
one LED
the sensor IC Pixart PAN3101DB
