Cambridge Audio A3i Power Cord and Transformer Replacement
Выберете то, что вам нужно
  1. Cambridge Audio A3i Power Cord and Transformer Replacement, Case: шаг 1, изображение 1 из 1
    • Remove 2 screws from each side of the amplifier.
  2. Cambridge Audio A3i Power Cord and Transformer Replacement: шаг 2, изображение 1 из 1
    • Remove 2 screws on rear of device. Slide top cover up and back from main case.
  3. Cambridge Audio A3i Power Cord and Transformer Replacement: шаг 3, изображение 1 из 2 Cambridge Audio A3i Power Cord and Transformer Replacement: шаг 3, изображение 2 из 2
    • Remove 3 screws on bottom of case.
    • Remove 13 screws on rear panel.
    • Do not move the rear panel too far, as the power cord is still connected.
  4. Cambridge Audio A3i Power Cord and Transformer Replacement: шаг 4, изображение 1 из 1
    • Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
    • It may require some wiggling, but it should slip out of the hole and then off of the cord.
  5. Cambridge Audio A3i Power Cord and Transformer Replacement, Power Cord and Transformer: шаг 5, изображение 1 из 1
    • Carefully de-solder ends of power cord from circuit board.
    • Keep track of the colors of the cords. The brown cord leads to the L on the circuit board, and this cord will lead to a fuse in the power plug. The blue cord leads to the N on the board.
    • Finally, pull the power cord through the rear panel to completely remove it.
  6. Cambridge Audio A3i Power Cord and Transformer Replacement: шаг 6, изображение 1 из 1
    • To remove the transformer the motherboard must be removed. This is to gain access to the solder on the power cords. -See guide for removing motherboard.
    • Remove the 4 nuts holding down the transformer bracket using a 7mm nut driver or socket.
Заключение
5 участников успешно повторили данное руководство.
Colby
Участник с: 04/15/10
338 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 28-36, Regan Spring 2010 Участник Cal Poly, Team 28-36, Regan Spring 2010
CPSU-REGAN-S10S28G36
4 членов
Автор 3 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 19
За всё время: 7,128
