Введение
Use this guide to replace the damaged or broken speaker cover of your Cambridge SoundWorks OontZ Angle Plus Speaker. The detailed steps will guide you if you are planning to customize your speaker and change the color of the cover. This is a relatively quick and easy replacement process.
Выберете то, что вам нужно
Carefully pull apart the bottom and top plates, using the blue plastic opening tool.
Once the plates are separated, slowly pull the bottom plate away from the top plate.
Use the metal spudger to bend the three bendable clamps on the ends of the speaker cover.
Next, use the metal spudger to bend the four bendable clamps on the bottom of the speaker cover.
Еще один человек закончил это руководство.
