Введение
The check valve replacement is straight forward. You will need to remove the shroud of the compressor. However, not much more disassembly is required for this replacement.
Инструменты
Запчасти
Никакие детали не требуются.
  1. Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench. Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench. Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
    • Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
  2. Remove the plastic shroud from the compressor. Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
    • Remove the plastic shroud from the compressor.
    • Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Gently pull the wire attached from the pressure switch to the on/off switch.
    • Gently pull the wire attached from the pressure switch to the on/off switch.
    • It should come off the pressure switch with ease.
    • Make sure you are pulling the correct wire. The pressure switch could be in a different configuration on your compressor than in the picture.
  5. Gently pull the wire connected from the on/off switch to the motor of the compressor.
    • Gently pull the wire connected from the on/off switch to the motor of the compressor.
    • It should be the only wire keeping the shroud from being lifted from the compressor.
  6. Unscrew the exhaust tube from the check valve using a Smart Wrench.
    • Unscrew the exhaust tube from the check valve using a Smart Wrench.
  7. Unscrew the check valve by twisting it counter-clockwise using a Smart Wrench.
    • Unscrew the check valve by twisting it counter-clockwise using a Smart Wrench.
Заключение
Caleb Davies
Участник с: 07.10.2014
501 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 14-29, Maness Fall 2014 Member of Cal Poly, Team 14-29, Maness Fall 2014
CPSU-MANESS-F14S14G29
4 членов
Автор 7 руководств
Один комментарий
I never thought that it will be that much easy. I was looking for this kind of guide and thanks to ifixit and author of this guide I have successfully did the check valve replacement. Thanks for sharing this.
http://zahroofvalves.com
Rodney A. Olsen - Ответить
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 5
За всё время: 869
