Введение
To replace the scanner bar, the glass must first be removed, and then the scanner bar can be easily removed and replaced.
Запчасти
Никакие детали не требуются.
  1. Slide the plastic opening tool under the plastic to unpeel it from the glass. Gently pry the plastic framing from the glass. Repeat on the other side.
    • Slide the plastic opening tool under the plastic to unpeel it from the glass.
    • Gently pry the plastic framing from the glass.
    • Repeat on the other side.
  2. Remove the front plastic frame. Remove the front plastic frame.
    • Remove the front plastic frame.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Wedge the plastic opening tool under the glass and pull up. Slide the glass forward. Remove the glass.
    • Wedge the plastic opening tool under the glass and pull up.
    • Slide the glass forward.
    • Remove the glass.
  5. Remove the scanner bar.
    • Remove the scanner bar.
    • Replace the scanner bar back onto metal center bar.
Заключение
Nick
Участник с: 28.10.2013
134 Репутация
1 Guide authored
Команда
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 4
За 30 дней: 13
За всё время: 1,178
