Введение
This guide demonstrates how to replace the bulb. This part will commonly burn out and need to be replaced, so knowing the steps to this simple repair will be very useful for a consumer.
Выберете то, что вам нужно
Unscrew the two 7mm Phillips #0 screws that attach the bulb to the mainframe of the projector.
Remove the bulb housing by gently pulling on the small silver handle located on top of the bulb housing.
You may replace the entire housing unit or replace the bulb itself once you remove it from the housing unit.
Еще один человек закончил это руководство.
