Введение
If you observe any problems inside your scanner, you will have to remove some components to do any work inside your Canon CanoScan N670U.
To reach the inner components of the scanner, you must:
- Remove the two side bars that hold the glass scanner bed in place.
- Remove the glass scanner bed itself.
Выберете то, что вам нужно
Open up your Canon CanoScan N670U to an upright position.
Turn your device so that you're facing the long side of the Canon CanoScan N670U.
Locate the small crevice between the plastic components of the scanner bed and the scanner base.
Carefully insert a metal spudger tool in the crevice and slowly cut through the adhesive between the plastic components.
Once the adhesive strip is sliced through, the plastic bar that is attached should release. Set aside the plastic bar.
Use your hands or a metal spudger tool to push the plastic bar at the bottom of the glass scanner bed forward until you can't push it any farther.
Insert the metal spudger tool underneath the glass scanner bed. The front of the scanner bed should be resting on top of the tool.
Еще один человек закончил это руководство.
