Введение
If you're having issues as a result of a dirty or faulty white document mat, this is where you will want to begin.
To remove the white document mat, you must:
- Carefully rip out the foam that's glued onto the cover.
- Glue in the replacement document mat.
Выберете то, что вам нужно
Open up the top of your Canon CanoScan N670U to this position.
The document mat is taped on to these four corners of the cover. These spots will be where we'll start removing the mat.
Gently peel the tape on each corner of the mat using your hands or an iFixit Tech Knife.
To reassemble your device, ensure that the white document mat is firmly glued on.
Еще один человек закончил это руководство.
